sundancer268
May 08, 2010Explorer
"Solder & heat shirking tape is by far the best connector if needed be, as suggested by another contributor."
Do NOT Solder any connection, That is worse than using solid wire instead of stranded. In the Boating World, the code requires Tin Plated Stranded Wire as it will flex with out breaking.
Use un-insulated crimp on solder-less connectors and Heat Shrink Tubing with the sealant inside. You will wind up with a weather proof connection that will last longer than the camper.
38,705 PostsLatest Activity: Jan 24, 2025
