oldtrucker63
Aug 30, 2010Explorer
bryan.h wrote:I think there will more than just the saving gas to the lawn mower option, It will also take a big load off the genny when using the AC and maybe the microwave at one time and I'm also adding a gas and electric water heater so when dry camping and running the AC it can also heat the water too and save the LP gas at the same time, I would say the lawn mower motor with say a 2500 watt inverter should run the microwave and TV coffee pot all at the same time and the genny will just run the AC and water heater at the same time, At least thats what I'm hoping for I think a 5500 watt genny should run the AC and water heater at the same time anyway, As with the roof, Well its Untelling when I will get the rubber on I was hoping soon But I need to paint the old dodge Before I put that rubber on to keep from having to mask it off so to keep paint off it, And to get the paint done there is a lot of houres of prep so that the paint will look professional, I do not have a lot of experience painting but I'm sure I can get the look that I'm trying to achieve' One thing for sure time is on my side, I would love to hurry and Get-R-Done But then ya tend to miss things and mess up and have to go back to refinish what you already refinished and I hate that, So I'm going to take my time and just do what I can and get it right, Thats the thing of this project anyway Is to Achieve a very professional look, I know for sure the inside will have it because that I know I'm good at, I just have to get the same on the outside too, The Extra weight on the rear should not be more than 200 lbs Not counting the weight of the lawn mower Engine one extra battery or the generator so what about 500 to 600 lbs or less.:holdtrucker63 wrote:
This welder will be used to Extend the rear frame and bumper, There will be room for a box container for the Generator and one for a lawn mower engine to drive a alternator that will be hooked to an Inverter a and to charge the house and start batteries.
Something like this...Click Here.
That is nice, I am sure adding a small lawn mower engine will save tons of gas as opposed to the genny charging option.
I looked at the roofing you plan on using and it looks very easy to install. How close are you to getting it on?
As for the welder, it looks great. I think you would have been finished with the MH project if you didn't pay such close attention to all the small details of every project you take on. I am sure you will have a great welder very soon.
How much weight do you think the additional frame parts you plan to weld on will set you back. I know in my MH I only have about 1500 lbs of load capacity total so I would not want to add framing if I didn't have too.
Keep the pics posted I am sure as soon as you finish the roof the rest of the MH will come together nice and easy.
38,708 PostsLatest Activity: Mar 05, 2025
