oldtrucker63
Sep 03, 2010Explorer
I found a good deal on a motor for my Alternator/Inverter/charger/AC Power source and should run the air compressor too so I can have air tools on board the rv and this could also be used to fill the 150lbs air tank for the air bags too. Anyway I found the 5.5 HP Honda wheelbarrow air compressor it looks a little ruff but I know the man that had this since it was new and the motor has not been run much at all Its just sit around collecting dirt, The motor had not been started in over 6 months and it fired up on the 2ed pull and runs great, He said the air compressor had quit pumping air, I found that the copper line is half broken and the compressor works just fine It just needs the line fixed So I will just add the alternator and a belt tensioner and it should run the compressor and the alternator with no problem.
38,705 PostsLatest Activity: Jan 20, 2025
