Jimmydi's avatar
Jimmydi
Tow capacity
Diane and I plan to buy an RV motorhome Class A. Very new to this venture and experience. We need your help. The tow capacity of the Class A Motorhomes vary from bus to bus. My question is, is the rating based on the transmission, rear end gear ratio or specifically related to the hitch and its strength. We have a 2008 vacationer Holiday Rambler Excel Kama 34 feet by Monaco. Tow capacity I believe is 5000 pounds. We would very much like to tow a 2013 Ford F 150 4 by 4 along with the Harley in the back end. That should be somewhere in the vicinity of 7500 pounds. Therefore, is it the hitch, rear end, gear ratio, this particular bus is a 325hp Diesel Pusher. Thank you and we'll probably see you out there sometime once we get this on the road. Thank you for your help
