rk911
Jan 11, 2017Explorer
jepalmer wrote:
I will be towing a vehicle and need to be able to easily (relatively) hook up the towed vehicle by myself.
1) Any recommendations for a particular tow bar brand?
2) Any hookup procedure recommendations?
Thanks.
piece of cake. I like the Blue Ox brand of tow bars and base plates primarily because of their commitment to customer service and satisfaction but the other mfgs. will have their proponents as well.
shop them all before deciding.
as for procedures...you'll develop a routine over time but two suggestions. first, develop and use a checklist until you have that routine and even then double check everything...always. second, don't let anyone interrupt you. that's when mistakes are made. if someone comes over to chat while you are hooking up or unhooking, stop what you're doing, complete the chat and then start over from the beginning to be certain you didn't miss anything.
the one issue you might have is checking that all of the dinghy lights are working properly. the few times I was out alone it was easy to check tail lights, blinkers and 4-way emergency lights. the brake lights were a problem since I couldn't be in two places at once. so I either solicited help from a neighbor or I used a length of wood against the brake pedal to keep it depressed while I checked the lights on the toad.
good luck.
38,769 PostsLatest Activity: Apr 24, 2002
