tropical36
Jan 23, 2017Explorer
Finally Time wrote:
I travel solo and hook-up the toad solo. I use a Ready Brute Elite. It takes me just under 5 minutes to hook-up and go. (Part of that time is due to having to go through a prep procedure for the Honda CR-V.) I am a check list fanatic, here's mine for the hook-up.
Hooking CRV to Motorhome
1. Move towbar legs up & out in a V position with legs retracted
2. Turn handles to right angles with legs
3. Drive car close to MH
4. Drop towbar from stow shackle
5. Pull out one leg and hook clevis to car
6. Pull out other leg and hook clevis to car
7. Turn handles parallel (in-line) with towbar legs
8. Wrap each safety cable over each leg & hook to car
9. Plug in light cable
10. Check that lights function
11. Hook up brake cable
12. Drive MH forward & check that arms are extended
and that pins have snapped down
If one pin does not snap down, drive MH forward
turning in direction of pin that didn’t snap down
Un-Hooking CRV from Motorhome
1. Park as straight & level as possible
2. Set car in PARK and set emergency brake
3. Unhook safety cables light cable, brake cable
4. Rotate towbar handles 90 degrees to legs
5. Remove cotter pins and bent pins
If pins too tight start engine, turn wheel right & left
6. Collapse legs and push together.
7. Turn handles parallel to legs
8. Push legs to one side, lift up and hook shackle over tow strap
9. Put cover over towbar legs
10. Put strap over shackle
11. If driving with towbar in stow position, tie legs together
and support with strap(s) to MH ladder & bumper
Even though, my DW is usually in the toad, during setup and follows my direction, there's something that you may want to try.
Once you have your bars connected, turn the toad wheels accordingly and idle back to lock them in. Takes a little practice, but now can't remember when the last time was for driving the coach forward to attain this.
38,769 PostsLatest Activity: Apr 24, 2002
