Mr_Mark1
Jan 27, 2017Explorer
Mr. FT,
I pull the CR-V up behind the coach then connect everything.
Then, I get in the Honda, put it in reverse to lock the arms on our Blue-Ox tow bar. After that, I run through the gears as you do and then stop in neutral, turn the key to the accessory position, then turn off the switch that controls the fuse to the Nav/radio.
Then off we go!
MM.
Then off we go!
MM.
38,769 PostsLatest Activity: Dec 31, 2017
