tropical36
Jan 28, 2017Explorer
Finally Time wrote:
Tropical36,
Preparing the CR-V for towing requires starting the engine, shifting through all the gears, then stopping in drive for at least five seconds and then into neutral for at least 3 minutes before turning it off. Generally I start with this, and while it is idling for the 3 minutes in neutral I hook up the tow bar. If I tried idling back to lock the pins, I would have to go through the whole procedure again before I could drive off with the CR-V in tow.
OK....and you should know by now. It's different toads for different folks and what their needs are... :)
38,769 PostsLatest Activity: Apr 24, 2002
