BillMFl wrote:
Badlybent wrote:
i have a problem finding a tow dolly that will work with our mini van,, i had a tow dolly that i could put my full size dodge truck on and use it BUT i cant use it with our 2011 dodge grand caravan :( when i load it on the dolly it has some room on both sides but when i try to turn the dolly fenders hit the side of the van about at the door hinge... when my truck is on there the dolly fenders go under the truck fender well and work fine but the van fender wells arent big enough, anybody know what to do about it? any suggestions? thanks
I tow my dolly with my E150 van sometimes. Can't see how the dolly fenders could hit your van unless you were turning extremely tight? Also even though the truck will fit on the dolly, you may be exceeding the load limit of the dolly depending on the weight of the truck.
i dont pull my truck on it i just put it on there to see if it would fit. the tow dolly is pulled by the motorhome and the dodge caravan is the toad, i tried to take it for a test pull but i couldnt get out of the driveway because i couldnt make the turn (not even a 45* turn) thanks
