mowermech wrote:
Mr. Mark, are you towing your Lincoln on a dolly? If not, what does your Manual say about towing 2 wheels down? Is it acceptable, not recommended, or absolutely forbidden?
It sounds like you are towing 4 down. If so, your success at that is totally irrelevant to the discussion at hand, which is about dolly towing.
But, thank you for your input.
I'm so bad. :R
The manual states that the 2017 MKX's can be towed four down no matter the powertrain/transmission configuration.
I looked in the owner's manual and there is no mention of using a tow dolly. They mention if I want to pull a trailer with the car or towing four down behind the motorhome but nothing on a tow dolly.
It will be interesting to hear what the OPer's manual says on his MKX.
MM.
