Larrysr1957 wrote:
I will be renting a uhaul tow dolly for a trip I will be taking I am pulling it with a 1998 35 ft. Bounder the vehicle being towed is a Lincoln MKX I will be traveling at approximately 60 mph 400 miles each way does anyone see any problems with this setup
I own an original Demco tow dolly as used by U-Haul. You won't find more steel in any dolly. Really built strong, but as you say no brakes. The first issue is make sure there is enough clearance at the bottom front so that you can drive it onto the dolly. I think the MKX is high enough, but the vehicles with down low air dams they won't fit. To be honest, I would advise you to get a unit with brakes. I think only the biggest diesel pushers would be safe with it without brakes. If you do rent it, you need to check the tightness of the straps after 15 minutes of driving and then whenever u stop check em again. On the flat lands keep way behind the vehicle in front of you, and slow slow down the mountains.
