FLHTCI
Sep 17, 2021Explorer
Tow hall mode
Greetings all, I pulled the trigger on a Winnebago Itasca Sunstar 30T. The previous owner drove it always in Tow Hall mode. Is this a wise decision?? I assume I should only use the tow mod...
way2roll wrote:
Do you mean tow/ HAUL mode? The Ford is equipped with a tow/haul mode feature that's very helpful when towing and especially helpful on descents. When in tow/haul mode you can tap the brakes on a descent and it will act similar to an engine brake allowing you to use less brakes and over heating them. In our previous MH, I found it helpful even when not towing in stop and go traffic as it changes the shift modes and helps slow you down without a lot of braking. But
the tow/haul mode is designed exactly for towing.
