Greetings all, I pulled the trigger on a Winnebago Itasca Sunstar 30T. The previous owner drove it always in Tow Hall mode. Is this a wise decision?? I assume I should only use the tow mod...
It should always be turned on. The F53 chassis is designed for many different iterations. However most of the class As will be heavy enough empty that it is considered hauling. An empty bread truck weighing 9klbs and you don’t need tow haul.
Tow Haul is great, changes the shift points to match the weight of the MH even more so when towing. And it activates the engine braking.
