FLHTCIExplorerSep 17, 2021Tow hall modeGreetings all, I pulled the trigger on a Winnebago Itasca Sunstar 30T. The previous owner drove it always in Tow Hall mode. Is this a wise decision?? I assume I should only use the tow mod...Show More
notevenExplorer IIISep 18, 2021One wonders why "not Tow Haul" mode is left available once a motorhome superstructure load is installed on a chassis ...anyways I use Tow Haul mode and M mode frequently towing and hauling with my F350 won ton The number one tip I can give for mpg and better performance with a flex fuel engine Ford truck is use 91 gas. I have no idea if F53 chassis engines respond to 91 or E85 in the same way.
