blknomad
May 31, 2016Explorer
tow haul
I have a 35ft 2014 f53 chassis. I have never used the tow haul mode but once and didn't much like it. Do any of you run it all the time? How does it work going up hill? I tried it going down hill and ...
blknomad wrote:it is doing just what it should be doing. You said that you "hit the brakes going down hill". That means that you were in too high of a gear as you should NOT NEED to apply the breaks going down a hill. You should be using the engine to control speed and NOT your brakes. It is doing what you should have already done.
I have a 35ft 2014 f53 chassis. I have never used the tow haul mode but once and didn't much like it. Do any of you run it all the time? How does it work going up hill? I tried it going down hill and every time I hit the brakes it down shifted when I didn't think it need to. Any input helpful. Thanks
