supercub wrote:
I have an 09 Ford Escape Hybrid for a tow vehicle.
I have to turn the ignition switch to unlock the steering wheel for towing. My question is, instead of using the factory key that has a chip in it for anti theft. Can I have a key made for just unlocking the wheel? If so, will it hurt anything on the car not to have a key in the ignition that doesn't have the chip? I only want to use the key when towing. Thanks
Brian
Shout answer: YES..
Long answer: Recommended you do.
Longer answer: Some cars you can remove the key in the UNLOCKED position (or for that matter any position) either by design or due to wear and tear on the cylinder.
