hohenwald48 wrote:
wa8yxm wrote:
 This system works well when new but has one problem in that the cable that operates the brakes is like a parking brake cable.. It can rust and size up like a parking brake cable does if you live in the wrong part of the country.
I've heard this before about the Ready Brake.  Usually from folks who don't own one.  I've never experienced this problem on mine and can't figure out how a stainless steel cable running inside a plastic conduit could possibly "rust" regardless of where you might live.
X2.....and the cable is constantly being exercised when the toad is is in regular use, unless you disconnect it from the pedal that is. I applied grease to ours, before sliding it into the sheath, as well.
