J-Rooster
Oct 29, 2016Explorer
wa8yxm wrote:Thanks for the explanation! I wasn't aware the two different parts were compatible. JohnJ-Rooster wrote:
I don't understand them using two different tow bar systems Blue Ox and Roadmaster together? And the cotter pin he shows? I don't use them (I've never trusted them) I use padlocks in the place of those pins.
Many people use either roadmaster tow bars with Blue ox base plates or the other way around. both companies make "Adapters" for selected base plates and/or are compatible up front.
The "Cotter Pin" is actually misnamed, that is called a "hair Pin" not a cotter pin... though they serve much the same function, Cotter pins would NOT have come out since you "Spread the legs" but cotter pins are not designed to be inserted and removed over and over again hair pins are.
I use spring clip pins there they have a curcular spring that is bi-stable (means it will rest in either of two position) we used these exclusively on the farm to hold the draw bar, plough, cultivator, mower and other 3-point hitch devices to the tractor and I've never had a problem with them.. I do not think they can come loose.
I used to use hair pins at the other end of the Tow bar however (Motor home end) till one came out exactly as described above and cost me around 2,000 in repairs, I now use either padlocks or pins you need to use TOOLS to remove. I do not trust the hair pins at all.
Page 2:
Padlocks v/s a "Quick Release" on the car end.
I have read of many a RV fire, even seen one (though that was a TT) and the faster I can disconnect the other vehicle (Towed in my case, Towing in the case of the TT) the less damage to the other vehicle.
In the case of the TT though it was the tow vehicle that went up. Some smoke damage to the trailer but nothing a good bath would not cure.
(Fire was already on scene when I drove past so I kept on trucking, he also had a friend with a 2nd tow vehicle so they could get him off the freeway w/o my help, I'm not rated to tow that much anyway)
I've also had a Tow vehicle that looked like it was on fire.. But was not. Turned out to be something easy to fix.. AAA tow and a new piece of transmission line and some fluid. (it was hot oil on a hot exhaust, lots and lots of smoke, and I mean LOTS of smoke, no fire though)
But I'm a firm believer in quick release in the event I need to quick release.
That said.. A second danger.. Some folks theorized the hair pin had been pulled as a prank when I lost my towed (Oh, the safety cables,, I always wondered "Will they hold" I now know.. they did) but due to some things I did not include above that would have been impossible, I thik I know how the pin got pulled, but of course can not prove anything... but it was an accident, not intentional. (I'd inspected the hitch a short time earlier no chance for anyone to pull the pin unless they were running very very fast)
38,767 PostsLatest Activity: Sep 19, 2016
