sehunter's avatar
sehunter
Towing 4 down
2013 Toyota Tacoma 2wd, manual trans. Anyone out there tow this 4 down and if so any precautions? Obviously successfully?
  • lanerd wrote:
    No Toyota can be towed 4-down without modifications. Been there, done that.
    There is a person here on rv.net who does tow his Tacoma 4-down but has a driveshaft disconnect that has been pretty much error free. However, have read several post of people who also have drive shaft disconnects but have had a LOT of problems. So be aware.
    Good luck
    Ron
    I towed my Toyota Yaris manual transmission all 4 down for years with no problems (Washington State to Arizona)
  • Triker33 wrote:
    f Remco Industries no longer sells the Drive Shaft Coupling (Disconnect). .
    gee, if they are as wonderful as folks here would claim, I wonder why remco dropped them? I believe they also dropped the one for front wheel drive vehicles.
    bumpy
  • J-Rooster wrote:
    I owned a 2010 Toyota Yaris manual transmission and I towed it all 4 down for years. All I did was turn the ignition onto accessary to unlock the steering. I can't see any difference in towing any Toyota that has a manual transmission all 4 down!
    sure go for it. I mean what could go wrong?
    bumpy
  • I owned a 2010 Toyota Yaris manual transmission and I towed it all 4 down for years. All I did was turn the ignition onto accessary to unlock the steering. I can't see any difference in towing any Toyota that has a manual transmission all 4 down!
  • Ron, could you give a little more details on been there done that?
    Thanks,
  • No Toyota can be towed 4-down without modifications. Been there, done that.
    Good luck
    Ron
  • 2013 Toyota Tacoma, Regular Cab Base RWD L4 2.7L cyl 5-Speed Manual Manual
    Notes
    This vehicle may need a drive shaft coupling (disconnect) to be towed with all four wheels on the ground. Remco Industries no longer sells the Drive Shaft Coupling (Disconnect). If interested in a Drive Shaft Coupling, please contact Southwest Drivelines (http://www.swdriveline.com) or David at Drive Shaft King (800-442-6329).
