bluwtr49
Aug 08, 2013Explorer II
discovery4us wrote:
Is the toyhauler 6400 total with all your toys or 6400 empty? If it is 6400 total you are probable OK with a WDH. You will be right on the edge and I would still upgrade the hitch but most 5000lbs. hitches are rated closer to 6500lbs. with a WDH.
Need to be a bit careful here. There is a good possibility that the receiver is not a WD version. These require arms going forward to frame members not just bolted to a sub-frame.
38,766 PostsLatest Activity: Jan 10, 2026
