JohnnyT
Aug 08, 2013Explorer II
82911 wrote:
I have a 2002 Winnebago 32V with the F53 chassis and the ford v-10 engine. Max towing weight is 5000# but I want to tow my 6400# toyhauler. I know I would have to get a 10,000# receiver installed but what else should I do?
The reality is that your chassis is not designed to tow that much weight... In addition to the Hitch... Frame strength is a factor, suspension components, Transmission limitations, Torgue and horsepower to pull without exceeding design limits will be in play. Brakes are also a key factor...
In addition the affect of that much weight affecting the overall handling and stability in windy conditions or challenging road conditions will make your proposed setup marginal.
While it is possible to overcome some of these issues my assessment is that your setup will be marginal... No doubt some have exceeded design limitations and have not had problems.
If I were going to do it anyway... Then I would focused on suspension enhancements for my chassis designed to enhance stability. Weight equalizing hitch and sway controls...plus the best trailer brakes on the planet...
JohnnyT
38,766 PostsLatest Activity: Jan 10, 2026
