This is probably one of the most asked topics on this forum, and there are so many variables to consider the threads end up with folks just stating what they tow and why. But it's really just a process, at least in my opinion of first determining what type of vehicle you want for a toad, one that works for your perceived use. Secondly, you need to determine which vehicles that you would want or need are possible to tow four-down (I'm assuming that is the towing type you plan on). Remco has their towing list, and the vehicle manufacturer is a great resource- although not the only and final authority as some may say. Lastly you need to know how heavy your motorhome can tow as equipped and find a vehicle that fits within those parameters. Then you can begin the process of researching tow bar and braking systems that are acceptable to you. The order in which you do the process of research doesn't really matter. But if it isn't done correctly you can easily end up with a vehicle that doesn't meet your needs, is not easily towable four down, or is too heavy for your motorhome. Careful, methodic research will eliminate these problems.
