I have a 2015 Equinox, but I don't dingy tow it. Here's from my manual: Look like you pull fuse 32 so the battery does not drain. To run you brake system, you may need to run a separate wire from the battery dedicated for the brake system used in the car.
Dinghy Towing
Front-wheel-drive and all-wheel-drive vehicles may be dinghy towed from the front. These vehicles can also be towed by placing them on a platform trailer with all four wheels off of the ground. For other towing options, see “Dolly Towing” following in this section.
For vehicles being dinghy towed, the vehicle should be run at the
beginning of each day and at each RV fuel stop for about five minutes.
This will ensure proper lubrication of transmission components.
To tow the vehicle from the front with all four wheels on the ground:
1. Position the vehicle to be towed and secure it to the towing vehicle.
2. Turn the ignition key to ON/RUN.
3. Shift the transmission to N (Neutral).
4. Turn the ignition key to ACC/ACCESSORY.
5. Turn all accessories off.
6. To prevent the battery from draining while the vehicle is
being towed, remove fuse 32, the Discrete Logic Ignition Switch fuse, from the instrument panel fuse block and store it in a safe location. See Instrument Panel Fuse Block on page 10-34.
{Caution
If the vehicle is towed without performing each of the steps listed under “Dinghy Towing,” the automatic transmission could be damaged. Be sure to follow all steps of the dinghy towing procedure prior to and after towing the vehicle.
Caution
If 105 km/h (65 mph) is exceeded while towing the vehicle, it could
be damaged. Never exceed 105 km/h (65 mph) while towing the vehicle.
Once the destination is reached:
1. Set the parking brake.
2. Shift the transmission to P (Park).
3. Turn the ignition key to LOCK/OFF.
4. Install fuse 32, the Discrete Logic Ignition Switch fuse. See
5. Start the engine and let it idle for more than three minutes before
driving the vehicle.
(Here's our "baby" beside "big brother" who simply loves to pull our travel trailer!)
