falconman
Nov 03, 2015Explorer
Our 06 Wrangler has a Smittybilt bumper with D Ring attachments. I use the BO adapters to attach the tow bar. The adapters are expensive but well made and work fine. You need to know the diameter of the pins on your bumper D Ring, either 7/8 or 1 inch. The D rings should be welded on both sides of the bumper for max strength and make sure proper grade bolts were used to install it.
38,782 PostsLatest Activity: Sep 02, 2026
