Mikeborny's avatar
Mikeborny
towing a Jeep with aftermarket bumper
Recently bought a 2015 Jeep Unlimited Sahara with a Barricade after market bumper. Blue ox said they only needed the plate thickness of where the "d" rings attached and the hole size for the d ring pin and they could modify a bracket. has anyone towed a jeep with the bumper and not the base plate?
  • The problem with Aftermarket bumbers is that they use all the same bolt points that the baseplate makers wanted to use. Can only bolt on one or the other. Be aware...hitch makers no longer weld hitches on because welds can fail.
  • Blue ox makes an adapter that fits the bumper but they want $250 for it. The entire baseplate is $390 i think. Although there will be no labor involved with bracket!
  • Yes, I had Tomken in Buena Vista, Colorado modify one of his standard aftermarket bumpers to have Blue Ox mounts in place of the standard recovery D ring mounts. With a bit of grinding on the D rings, they will fit on the Blue Ox mounts when not towing. The bracket plate is welded to the bumper and bolted through the bumper directly to the frame. His price was competitive with comparable aftermarket bumpers.
