Vintage465
Dec 20, 2015Nomad
Towing a small car with a class B
So my sister-in-law is prepping up a 2015 Mercedes 4x4 van into a camper. It has some kind of small diesel engine......I assume they are all the same. Don't know what the rear axle ratio is either....and again, I kind of assume they are all the same. The conversion is going to be pretty basic and likely no where near the weight of a the normal class B. Based on this real thin info I have given you guys, what can she pull with this? What can you pull with a pretty loaded down factory equipped Class B. I would think that if a pretty loaded down class B can pull any kind of light weight car like a RAV-4 then she should be able pull at least that.
thanks,
thanks,
