wa8yxm
Mar 01, 2014Explorer III
Many can, I used to tow a 1992 Chevy Lumina APV. with a Remco Axle Lock (Turns it into a true trailer (This seats six or 7 as I recall.
Some considerations: What is the Max Combined Gross Vehicle Weight of your motor home
What is it's loaded Gross weight
Make sure the Mini-van you choose is at least 100 pounds less than the difference.. plus.. What is the hitch rating, You also need to be below that. if you use a drop hitch (As I did) the hitch rating can easily get a /2 after it's stated capacity (IE: 5000 pounds / 2 = 2500 pounds. Which by the way is what I now pull).
Google Remco towing, go to the store link and enter the vehicle info for what you have or what you are considering, the web page (if it's new enough) will tell you what can and can not be towed and what you have to do to it.
38,764 PostsLatest Activity: Dec 25, 2025
