- rv2goExplorer IIThe 2006 Avalanche 4x4 is listed a towable in the 2006 FMCA Towing Guides.
"Must have four-wheel-drive transfer case; not all-wheel-drive or two-wheel-drive." Weight, 5678 lbs. - AprilWhineExplorerYou can tow anything if you're determined. :) You may have to put the truck on a tow dolly or even a full trailer, but it can be towed.
- lanerdExplorer IIDepends on if the Avalanche can actually be towed 4-down. Check owners manual and http://remcotowing.com/.
Also, depends upon the weight of the Avalanche and if your mh is rated to tow that amount.
Ron - dons2346ExplorerRead your truck's owners manual.If it can be towed, there will be instructions on how to do it.
38,705 PostsLatest Activity: Jan 24, 2025
