Hello, I plan to flat tow my 08 Wrangler 2door with a 96 ITASCA 34RQ with a Ford 460. Has anyone done this and what should I expect. I'm a little concerned of straining the engine. I have a roadmaster...
Thanks for the replies. I will look for those numbers this evening. I did weight the coach last year fully loaded it was right at 16K. Is the GCVW the total weight on the axles? If I'm flat towing would that mean I'm not putting any additional weight on the axles? If the most I can haul in or out of the MH is17K, what's the point of adding a hitch? I mean I know others are pulling vehicles with these old Gasser's.
