Alex and Tee wrote:
The rear axle is rated at 17,500 with liquid springs, 15,500 without. I think what I need to find out is what the curb weight is so I know what the difference is between that and GVWR..
I know your right but the MH needs to be loaded up ready to travel with full fuel and if you dry camp, full water. This difference is the key number on how much you can tow and as long as it’s 4600 lbs or hopefully more (up to 5000), you are good to go. The liquid spring version should have a GVW 2000 lbs greater than the regular version.
