LaTriker
Mar 25, 2014Explorer
I pull a 2012 Buick Enclave. I have to remove two fuses and I also crank the auto at noon each day and run the tranny through the gears. Once you get used to it, removing the fuses is not a problem. I also had a non-chipped key made which will turn the key to accessory (required) but will not crank the engine.
