lanerd wrote:
No Toyota is towable either 4-down.  Has to be modified with either a lube pump for the trans or a driveshaft disconnect.  FWD models can be towed on a dolly.
The 2wd Colorado is not towable either 4-down or on a dolly  Same restrictions as above.
The 4wd Colorado IS towable either 4-down or on a dolly.
Go to remco website to determine which vehicle is towable or not.
Good luck
Ron
We can tow a Toyota Yaris 4 down (standard trans).   But yes, for most of the vehicles outside of standard you have to modify.
