Ready set go wrote:
2011 DiesalTiffin Allegro Red open Road 36’
May need to have it towed. Read owners manual it said remove drive shaft and tow. So can or how should it be towed. From front or rear? Should it be towed or lifted onto a flat bed??
Anyone have so actual real world experience with this.
Having it towed, from the front , with drive line disconnected, not necessarily removed. Make sure the towing company is familiar with MH towing,
I said disconnect, as opposed to removed, the rear of the transmission will leak fluid if the drive line is removed for the transmission. The would remove the bolts from the universal joint at the differential, then secure the drive shaft to the frame.
