Remove drive shaft, tow with bus lift. The bus lift goes and behind the front wheels and lifts the front by the wheels/tires so no change of frame or suspension damage and also avoids the possibility of damage to teh front facia of the coach . That's what Freightliner told me to do... especially important to do it this way due to the independent ZF front suspension.
Your RED may be different-- call Freightliner and ask them .
Depending on thew route it needs to be taken, using a low boy may or may not work. With the height of the MH at nearly 13 ft. then add 2+ ft for the
low boy, you'll have clearance issues on going under many bridges.
