dougrainer wrote:
The WEIGHT/LOAD limit for the HITCH is what the HITCH is designed for and the Chassis mount/frame is designed for. You CANNOT just add a 10k hitch and think you are OK. Some Chassis/Frames you can install a 10k hitch but you must first find out from the Chassis maker if that is possible. If NOT, you can go to a certified welder and have him beef up the rear chassis/Frame to allow a 10k hitch to be installed. Doug
This!
Please don't overload your hitch....you not only risk frame damage to your rig, you more importantly risk hitch failure and consequently an accident involving much higher stakes than just damaging your own equipment! Plus, if your chassis isn't designed for the weight, it may not have adequate braking or suspension capacity either. It's easy to "PULL" a heavy load, but "STOPPING" it is a whole other thing. Engineers don't just stamp an arbitrary number on products for fun.....
