rk911 wrote:
hohenwald48 wrote:
rk911 wrote:
Ductape wrote:
Get a 10k hitch installed.
there may be more to it than just changing the hitch. for one the brakes on your MH are engineered for the GVWR of the MH, not the MH plus the toad. if you decide to do this please consult with a professional who can properly advise you.
Don't toads and trailers have their own brake systems and as a result do not use any of the towing vehicle brake capacity?
sure they do. but unless there is an intentional hookup between the MH and toad the towed vehicle's brakes are not used. we've been towing our jeeps since 2003. in order to be able to activate the jeep's brakes while towing we needed to install an auxillisry brake system in the jeeps. in short when i step on the brakes in the MH i get a progressive and proportional braking of the jeep. without that aux. system the towed vehicle is just dead weight.
So, a properly connected toad (trailer) will have no impact on the stopping ability of the towing vehicle. I thought you were saying that towing capacity was limited because ". . . for one the brakes on your MH are engineered for the GVWR of the MH, not the MH plus the toad." If the toad (trailer) has it's own brakes then the towing vehicles brakes don't need to be engineered for the GVWR of the MH plus the toad. Correct?
