way2roll wrote:
Tom/Barb wrote:
I must have dumb blind luck.. I never gave any attention to the hitch when I bought our coach. But after reading posts here about hitches I went out and looked.
Our hitch is all welded into the rear frame of the coach and rated at 10K.
Now I believe I know why Newmar has the reputation they do.
Better coach,= less worries.
Most DP's have a 10k hitch.
I'd agree to "some" if you look at ALL DP's on the road. I agree that "most" newer DPs have a 10K hitch.
for the OP...
in general, the maximum amount of weight you can safely tow will be the
lesser of the following:
- the GCWR (gross combination weight rating) of the MH minus the actual weight of the MH (defined as the sum of the actual weights on each axle) as it is loaded for travel (includes fuel, fresh water, food, clothing, people, pets, supplies, etc).
- the weight rating of your tow bar
- the weight rating of your hitch
this is why it's vital to know what your MH weighs as it is loaded and configure for travel before choosing a toad. Your MH will not collapse if it is overloaded but you will experience handling issues as well as longer braking distances and accelerated wear on suspension, brakes, steering, etc.
some might suggest simply subtracting the GVWR from the GCWR to get your max tow weight. while that's true to a point it also assumes that the
actual weight of your MH does not exceed the GVWR. better to know than to assume.
