mgfiest's avatar
mgfiest
Towing... what is the cost????
I read about some disadvantage with towing but they don't really go into the cost of this disadvantage.
So what disadvantage I would like to know is the fuel consumption lost. Either gas or diesel. If you can go 600 miles on a tank without a toad... will you only get 300 miles on a tank with a toad. If you use a toad, do you need to upgrade your transmission to accommodate, if so then that is an added cost. Then there is the brake system.. I assume that is an added cost.
So I am thinking there is a major add on.. if you do tow a vehicle.
If it gets that much... it maybe better to rent a car, when you get to your destination.
  • Maybe $2-3000 to get tow setup on your toad.
    I have insignificant mileage difference.
    It will cost you ABOUT 1/2 mile to the gallon of fuel. Personally I dont use a supplemental brake
