fcooper
Nov 17, 2016Explorer II
A good lightweight tow bar.
The earlier 5,000 lb rated models would wear the bolt holes at the end of the tow bar arms where the arm bolts to the triple lug brackets (brackets that attach to the toad base plate). The soft aluminum would eventually allow the hole to become egg shaped instead of round. This happened to me after towing a 4500 lb toad for many years and many miles.
I have no experience with the newer 7,500 lb rated models. This problem may have been cured on the newer versions.
I'm now using a 10,000 lb all steel model, and I miss the light weight Aladdin. :)
Fred
Fred
38,766 PostsLatest Activity: Jan 10, 2026
