Executive45
Apr 07, 2020Explorer III
Aladdin System (Update)
For those that responded to my earlier post about the Aladdin tank sensors, I thought I'd give an update. I went ahead and ordered the SeeLevel 709 system and installed it today. I decided to mount the display in the wet bay instead of inside the coach for the time being. I may order another display for inside but I think the one will suffice for now. The install was pretty simple. I mounted the sensors on the side of the tanks, fished the wires (two) to the other side, encased them in split loom and attached them to the display. I grounded the unit to the frame using a lug purchased from Home Depot. For power I used a three gang box in the wet bay which is turned off via the house battery switch. I used 14 ga motor wire. I was also able to cut out a lot of unused wire behind the panels and zip tied everything so they are secured. I am pleased with the results. Below are a couple pictures....thanks again for those that responded to my earlier post....Dennis
