rjstractor
Jun 26, 2013Nomad
If the hitch capacity is listed as 3500 lbs trailer weight and 350 pounds tongue weight, then that's just what it is. You have to make sure you are not over your chassis Gross Combined Weight Rating and your rear axle's maximum weight. If you have a 1000 pound cargo load and your trailer weighs less than 2500 pounds empty, then you should be fine.
38,766 PostsLatest Activity: Jan 10, 2026
