j-d
Jun 27, 2013Explorer II
By 500-1000# I think you mean the load in the trailer, not the trailer tongue weight. If it's load within the trailer, then what does the empty trailer weigh? If the traier weighs 500 empty and you put 1000 in it, that's 1500 and your tongue weight shouldn't need to be above 150 to tow the trailer without having it whip behind the coach.
How heavy is the coach, as loaded for travel? Jayco stuck a label by our hitch saying the coach brakes are rated at GVWR (max fully loaded coach weight) not GCWR (coach and trailer combined). That could mean that you should have brakes on your trailer, even if it doesn't fall under state DMV rules to have brakes on it. For example, our 2002 E450 has GVWR 14050. Say we actually scale out at 12500. That'd leave 1500 that Ford wouldn't expect to have its own brakes.
38,766 PostsLatest Activity: Jan 10, 2026
