Your Patriot requires battery power from the toad to work. Unfortunately, most cars 12v outlets do not power up with ign. key in off position or will time off shortly after key off.
You need to install, or have installed, a 12v outlet that is live all the time. Plug your Patriot into that and you are ready to go. Most install this full time outlet down by driver feet on the kick panel or e-brake bracket.
Remember, the Patriot will require about 4 hours time plugged into a hot outlet in order to recharge it's internal battery. This battery is not used to stop your toad under normal use. It is there to power the brake if the break-away cord is pulled out to power the Patriot while the toad stops itself. If you plug in and take off down the road, the Patriot will work fine but needs a few minutes charging time before emergency power will available.
