jwmII
Aug 13, 2015Explorer
rgatijnet1 wrote:kdk wrote:
IMHO regardless if it is required or not it should to all sensible people to use one regardless of weight or stopping distance. Everybody knows tow bar systems do on occasion break and when they do you could have a vehicle going down the road with nobody in it and with out a break away system this projectile could impact another vehicle causing serious injury or even death. I personally don't care if it required or not I'm using one as I don't want to be responsible for killing another individual or worse a family because I thought I could save a few bucks. If I can't afford some type of braking system that would help stop me sooner or a break away vehicle than I (and you RVR's) need to find another hobby. I don't think I could live with myself if I caused an accident that killed another adult or worse a child because I thought I could save a few dollars. Bottom line is purchase one with a good break away system and call it part of doing business or be prepared to loose every thing you have in court. So lets put this subject to bed and enjoy RV'ing.
Blessings; KDK
As I mentioned I use one in my toad but now I have to assume that if your braking system ever fails, you will immediately disconnect your toad and leave it behind or have your wife follow you until you can find another brake system.
If you read all of the posts, COST or being able to afford one, was never mentioned by anyone.
It is not a case of not being able to afford the brake unit, it is just like the Guy who buys the new boat and then is to **** tight to buy a rope to tie it up or anchor it with. The same to tight scenario applies to the motor home Guy.
38,782 PostsLatest Activity: Sep 10, 2026
