I have seen a few post on the toyos. I am a fan of toyos but I noticed this new set I have says 125psi cold. But the dealer only put about 95psi? What should I run in them to get the best performance?...
Just about any tire pressure chart for your tire size will provide the pressure required to support your MH’s weight. Use your GAWR to determine pressures until you get actual weights, or pressures displayed in your unit. The numbers on the tire are your last resort pressures and rarely required on a MH.
Best performance and best ride will most likely require different values!
