I have seen a few post on the toyos. I am a fan of toyos but I noticed this new set I have says 125psi cold. But the dealer only put about 95psi? What should I run in them to get the best performance?...
Check the placard on the wall under the window next to the drivers side seat. It will detail recommended tire pressures for the front and rear axel's tires. Set your new tires at these until such time that you weigh your coach to determine the manufacturer's recommendations. I highly doubt it will be as high as 125 psi.
