gsf35099
Jun 20, 2015Explorer
GlennLever wrote:
Had them, weight (centrifugal) pushes them up against the rims and bends the valve stems on rubber stems on the trail, Got rid of them because of that
One should absolutely install metal stems to use the sensors. The sensor weight is enough at higher speeds to actually pull the rubber valve stems out over time.
38,782 PostsLatest Activity: Sep 18, 2026
