Flanz's avatar
Flanz
TPMS - Flow Thru or Non Flow Thru Sensors
I've decided on which TPMS I'll purchase, so I'd like to keep this thread about sensors, please. Also, my tow vehicle will NOT have flow thru sensors on it, so I'm only concerned with the MH.
I'm in the process of deciding which sensor I should go with. I like the easy of the flow thru sensors, but having them may be another point of failure since there's another Schrader valve involved. Since the motorhome has solid metal valve stems, I'm not really concerned about the sensors moving around while driving, but I'd like to hear opinions.
As for the non flow thru my only cocnern is removing them every time I go to check, air up, or down my tires. Do you find that the locking mechanism will have fatigue over time? Are they difficult to work with? Do I have to recalibrate the TPMS if I remove a sensor when I want to put a pressure gauge on the stem?
Just looking to make a purchase one time on a TPMS. I've never owned one and would like to get a feel for the sensors...
Thanks,
Paul
