jorbill2or
Mar 27, 2017Explorer II
Non flow thru , no security device. Don't want the spinning weight and complication . Never had a security problem.
Never had a "seating" problem .. just a tiny psst of air as they seat. Once I check the air with a gauge then install the sensor I don't check with a gauge again unless there is a problem .. it's easy to spin it off to check or add air My belief is that's why I installed the system in the first place. To keep track of tire pressures.the sensors are my "tire gauge" Ea day I visually inspect the tires ( bumps scrapes rim condition lug nuts etc I still bump the tire an old truck driver habit I haven't broken ) check the monitor for proper pressures and go ! Easy peasy I set my tires and don't adjust
38,783 PostsLatest Activity: Sep 23, 2026
