cj7365
Jun 20, 2015Explorer
427435 wrote:Belgique wrote:
I've had both (TST brand...great folks) and nothing but flow through from here on. When you're trying to get the exact pressure with non-flow, you air - take off sensor and check - re-air - etc. etc. I'm lazy and if I have to do all that I take short cuts.
If you're adjusting pressure with the non-flow thru type, why wouldn't you just take it off and use a regular hand gauge until you had the pressure you wanted?
You will have a difference in pressure readings from your TPS monitor and what your air gauge says, mine is a couple pounds off, which in my opinion is not going to matter.
with the flow through, you can add air and use your TPS monitor to get an "exact" reading.
I am not going to be worried about if my tires are a couple pounds off
38,783 PostsLatest Activity: Sep 23, 2026
